It is currently Thu Aug 14, 2025 8:42 pm
PostPosted: Thu Jul 30, 2015 10:21 am
I used to pay ~ $45 for a 36" x 4" x .5" board on ebay (for neck blanks) but I am having a hard time finding it now. I do have the option of driving a couple hours and buying a big sheet and cutting it so it will fit in my GTI, but I would rather get smaller pieces. If you know of a source, I would appreciate it. Thanks.
PostPosted: Thu Jul 30, 2015 11:09 am
First name: Danny
Last Name: Vincent
It seems like a bit of an unusual wood for necks Lac. It is pretty commonly used for flooring I believe. Phone a few flooring stores.
PostPosted: Thu Jul 30, 2015 11:14 am
First name: Hugh
Last Name: Evans
Indeed, flooring suppliers are likely your best bet. Also, Bamboo isn't lumber: it's actually just a very large species of grass, which is why it grows so quickly and has so many issues with dimensional stability compared to actual wood. I think it has great potential for future engineered materials.
PostPosted: Thu Jul 30, 2015 11:29 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Makes good panda bait too
PostPosted: Thu Jul 30, 2015 1:57 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I saw bamboo laminate counter tops at Rona Lumber, recently. If you go the flooring route, not all bamboo T&G is created equal. Higher priced flooring is usually manufactured to a much better standard.
Alex
PostPosted: Thu Jul 30, 2015 2:35 pm
Thanks all. I would not describe the three necks I have made with it as unstable. My understanding is that the grass is boiled to get the sugar out, and soaked in epoxy. It is pretty close to working with real wood. Occasionally there is a tiny bit of fraying of the strands. And rubbing your hand up and down the neck while shaping will get you plenty of splinters. Flooring stores is a good idea. Most of the bamboo I find there is either not the minimum dimension I need, or has a bamboo face glued on to something else.
PostPosted: Wed Aug 05, 2015 1:06 pm
Last Name: Welch
City: Spokane
If you're in the Pacific NW/Canada, Windsor Plywood has carried it. I picked up a board awhile back with plans to use it somewhere...
PostPosted: Thu Aug 06, 2015 12:45 pm
First name: D
Last Name: S
Our good friend Stuart Gort has used it, you might give him a ping.
wah
Wah-wah-wah-wah
Wah
